TGao
6 years agoC10GX Transceiver不用的时候,VCCT_GXB,VCCR_GXB应该怎么接?
Hi 您好, 在C10GX中,高速口不使用,在引脚说明中,VCCT_GXB有明确的说明,如果不用可以接地。但是VCCR_GXB没有说明是否可以接地,我们应该怎么连接呢,是否应正常供电。谢谢 Ted
CheepinC_altera
6 years agoHi Ted,
AS I understand it, you have some inquiries related to the connection of VCCR_GXB when the XCVRs are not used. For your information, all the VCCR_GXB must be powered on even though the XCVRs are not used so that the device can operate properly. You may refer to the C10GX pin connection guidelines -> "Table 9. Transceiver Pins" -> "VCCR_GXB[L1] [C,D]" section for further details.
Chee Pin
