19 years agobyteblaster not showing up in hardware
Hi, I need help with my maxII eval board. When I go to program and verify, the byteblaster does not show up. I have a pci-parallel card in my dell computer and I have added that hardware to my ...
16 years agoHi wmrsouza (http://www.alteraforum.com/forum/member.php?u=26760),I am facing problem as yours. I use a PCIe Parallel port card, Installed it's driver and also the byteblaster's but when i program the PFGA it shows that "kernel mode driver not installed".I've changed the regedit follow as your suggest,but it still does not work now.
My PCIe Parallel port card's type is MM-PCEMM9901 which powered by MOSCHIP . it phsical I/O adrress is D000-D007. I do not understand why Quartus2 can't find the LPT1 port,and how can i save problem,please?:confused:
