19 years agobyteblaster not showing up in hardware
Hi, I need help with my maxII eval board. When I go to program and verify, the byteblaster does not show up. I have a pci-parallel card in my dell computer and I have added that hardware to my ...
16 years ago --- Quote Start --- Now my Byteblaster2 is running with my PCI parallel port adapter. The problem was during QuartusII installation the field "DependIOnService" of AlteraByteBlaster (HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\AlteraByteBlaster) in Windows registry was filled in to be dependent from service "parport". When I installed my PCI parallel port adapter (MosChip chipset) the service installed to take care of parallel port was NmPar. Since I pointed "DependIOnService" of AlteraByteBlaster to "NmPar I dont have problem using Byteblaster2 anymore. --- Quote End --- Thanks wmrsouza, you just saved my tearing my hair out in frustration. I have Parallel port PCI add in card based on a MosChip device. For reference: My port is LPT1. Is NOT at any of the old standard addresses (278, 378 or 3BC). I do have 'Enable Legacy Plug and Play detection' ticked in device manager but I have not tested if that is necessary yet. I have ‘Never use an Interrupt’ ticked in device manager. I changed the reg key as you suggested, rebooted and the byteblaster became usable :-) Regards, Mark Leman
