19 years agobyteblaster not showing up in hardware
Hi, I need help with my maxII eval board. When I go to program and verify, the byteblaster does not show up. I have a pci-parallel card in my dell computer and I have added that hardware to my ...
16 years agoI had the same problems with ByteblaserMV and WinXPSP3 with parallel prot on a PCI-Card.
First the ByteblasterMV was not showing up in hardware. --> change port to LPT1 (including activating an option for lecay-support on the PCI-card.) Then the problem showed up with "Kernel mode driver not installed". --> I installed the driver for the byteblaster before .. so i installed it again. http://www.altera.com/support/software/drivers/dri-bb-xp.html This solved the problem for me.
