19 years agobyteblaster not showing up in hardware
Hi, I need help with my maxII eval board. When I go to program and verify, the byteblaster does not show up. I have a pci-parallel card in my dell computer and I have added that hardware to my ...
17 years agohello,
can it be possible to connect a ByteBlaster MV Cable through a parallel-serial/usb adapter to a serial/usb port of the computer? i have this cable, but i don't want to use it on the parallel port of the computer, the main idea is to use it on a laptop, and laptops usually don't have parallel ports. that's why i'm wondering if the adapter might be a solution to connect the ByteBlaster MV Cable to a serial/usb port Does anyone have a sugeston or an idea? Thank you very much
