19 years agobyteblaster not showing up in hardware
Hi, I need help with my maxII eval board. When I go to program and verify, the byteblaster does not show up. I have a pci-parallel card in my dell computer and I have added that hardware to my ...
18 years ago --- Quote Start --- Hi ecm, I finally got it working, thanks for the advice. When I went into the device manager window, my pci parallel card was on LPT3 and I changed that to LPT1. Then the byteblaster showed up in the hardware list, but it said something about a missing kernel, so then I added the byteblaster driver again and also a .dll file that it needed and then opened up quartus again and finally I could add it and use it to program the device. Thanks, Elliot --- Quote End --- Hi, I know this is not a new thread, but I have the same problem, I already changed LPT3 to LPT1, and reinstall the drivers but it's still not working, keep giving the same kernel error, what else could be?? by the way which *.dll file is missing?
