19 years agobyteblaster not showing up in hardware
Hi, I need help with my maxII eval board. When I go to program and verify, the byteblaster does not show up. I have a pci-parallel card in my dell computer and I have added that hardware to my ...
19 years agoI regret to tell that based on my experience I was not able to resolve the problem You described either.
Indeed, I have tried to install the BYTE-Blaster on Parallel Port installed on a PCI card (since my motherboard LPT1 was used by a software dongle) and I could not get it to work. Since I did not have time to spent on troubleshooting this problem, the only solution that I found was to purchase a USB Blaster: I know that this is quite of an amount of money to be spent if You are not going to use it frequently, but the USB-Blaster has several advantages compare to the BYTE-Blaster. I hope that someone will be able to provide You with the possible solution.
