16 years agoByteblaster compatible expresscard parallel ports
Hi I've bought an off-the-shelf expresscard parallel port for use with a laptop, however it doesn't appear under "ports" under "device manager" (Win XP). It does appear as "USB Printing Suppor...
16 years agoHello,
Franks, thanks for the link! I did not see it before. I did not try the Byteblaster yet, it so I can't say it will or will not work. However it seems the LPT1 solution is a bit tricky? Am I better off just to invest $40-$50 and buy the USB cable? If so which one should I get? Thanks, Eitan
