BURST ACCESS with UNIPHY DDR-FPGA and DDR-HPS memory controller in CYCLONE V, using QUARTUS Prime 18
- 5 years ago
Hi GuilleJake,
The controller can identify the burst operation from user's command.
When user assert the address, burstcount, read or write and data, the controller knows that the user want to do the burst operation starting at the address with the burstcount value.
So when there is a burst signal such as burstcount, the controller will know that this is a burst operation.
Then the controller will act accordingly to do the burst operation.
They do not need the beginbursttransfer signal to start the operation because the controller is smart enough to identify the operation.
Adzim
Hi GuilleJack,
I'm Adzim. Thanks for using Intel Community.
Yes you are right about the beginbursttransfer signal.
The beginbursttransfer signal exists to support the legacy memory controllers as stated in the Avalon Interface Specification at page 17.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/mnl_avalon_spec.pdf
There are a lot of information regarding to your question that contain inside the Avalon document.
You should refer to the link above in chapter 3.5 about the read and write transfer processes.
For the maximum burstcount, you should count it with the formula 2^(N-1) where N is width size.
The width should be 1 - 11.
Adzim
