bsp-editor not found in SoC EDS Pro 19.3
May I know from which link you downloaded the SoC EDS Pro from?
I have checked in my directory there is a bsp-editor.exe in my folder.
I recommend that you re-download the software again and install here:
http://fpgasoftware.intel.com/soceds/
In the mean time I'll try to re download and reinstall to check again if everything has installed properly.
Regards.
- YTagu56 years ago
Hi, el.ign,
Thank you for your reply.
Yes, last time I have downloaded SoC EDS Pro from that link.
This time, I uninstalled SoC EDS once, then reboot the computer, download and installed again.
But bsp-editor.exe was not found. Instead, I see "com.altera.embeddedsw.bsp.editor.jar" in preloader folder. The situation does not change.
By the way, each time installing SoC EDS Pro, the installer gives no error and finishes. However, when I try to use SoC EDS Command Shell, the .bat file won't run because cygwin is not installed automatically.
So I install cygwin manually, reading the instruction in "C:\intelFPGA_pro\19.3\embedded\cygwin_setup" folder. Does this making problem?
Best Regards
- EBERLAZARE_I_Intel6 years ago
If you preferred the bsp-editor GUI, please proceed to use the 19.1 version of SoC EDS. The bsp-editor GUI is removed in 19.3.
I have confirmed in 19.1 SoC EDS, the bsp-editor GUI is available.
FYI, using the command line in the link below to generate the bootloader will use newer bootloader as compared to the bsp-editor GUI which is using the old version:
https://rocketboards.org/foswiki/Documentation/BuildingBootloader
Best Regards.
If you are using Windows to install the SoC EDS 19.3, you will need to install the cygwin manually. Please follow the steps to install the SoC EDS below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_soc_eds.pdf#page=12
Have you try running SoC EDS and bsp editor after installing the cygwin?
Hi Yoshitaka,
Starting from SoC EDS Pro version 19.3 and SoC EDS Standard version 19.1;
Our Stratix 10 SoC and Agilex does not use SoC EDS bsp-editor . However, the bootloader generator(bsp-editor) is still used for Cyclone V and Arria 10 and the steps to build are available below:
Thanks!
