Sruk
4 months agoBrand new USB-BLASTER 3 issues
A day ago I received a brand new and very expensive USB Blaster III from DigiKey with the following Serial Number: UB3000432 I have an issue using this device. The device is visible both in Win11 De...
- 4 months ago
Engineering sample means that the part is pre production and not suitable for industrial use. So one of the early production batches for engineers to play with and get used to the new board.
Considering your troubleshoot, I will request a replacement shipment from Customer Resolution team.
DigiKey
Zvi
4 months agoAre you using a 1.27" pitch connector or a 2.54" pitch connector? Are you using the JTAG adapter?
According to USB Blaster III user guide, the JTAG pins order of the 1.27" connector is different than the 2.54" connector(which was used by previous JTAG cables).
