KCMurphy's avatar
KCMurphy
5 years ago
Board Test System doesn't execute Arria 10 GX Dev Kit
Trying to get into a Mouser-supplied Intel Arria 10 GX Development board. I have the built-in USB blaster hooked up and the driver seems happy. The board is able to find the network and display its little browser.
No known issues. Win 10 Pro 2021H2, Quartus Pro 21.2.
Yet when I try to fire up the BoardTestSystem.exe app as described in the user guide, I get NOTHING. No error, nothing. Task Manger sees nothing. Doesn't matter what half of the flash the board is set to.
I know this is probably a cockpit error and there is something I don't see, but what?
(I know it says "new user" but I've been dealing with Alteras since the early Max days. Which makes this doubly frustrating)
  • Hi,
    If you go to your quartus installation folder under nios2eds folder you will observed
    nios2_command_shell.sh" for Linux and "Nios II Command Shell.bat" for windows.
  • JohnT_Altera's avatar
    JohnT_Altera
    JohnT_Altera
    May I know if you launch the GUI from "Nios II command shell"? If yes, could you provide me the screenshot of the issue as I suspect that there is some error when you execute the GUI.
    • KCMurphy's avatar
      KCMurphy
      OK. I have never had the need to deal with NIOS before. Obviously I have a learning curve here. I don't even see Nios Command Shell in 21.2
  • KCMurphy's avatar
    KCMurphy
    Thank you. I would never have guessed (and the 135-page manual never mentions) that I'd have to install a Linux package to make this work. A bit of a rabbit hole, too. But thank you for telling me where to start.
    • KCMurphy's avatar
      KCMurphy
      Thanks. Got there in the end.
