KCMurphy
5 years agoBoard Test System doesn't execute Arria 10 GX Dev Kit
Trying to get into a Mouser-supplied Intel Arria 10 GX Development board. I have the built-in USB blaster hooked up and the driver seems happy. The board is able to find the network and display its...
- 5 years ago
If you go to your quartus installation folder under nios2eds folder you will observed
nios2_command_shell.sh" for Linux and "Nios II Command Shell.bat" for windows.
JohnT_Altera
5 years agoHi,
May I know if you launch the GUI from "Nios II command shell"? If yes, could you provide me the screenshot of the issue as I suspect that there is some error when you execute the GUI.
- KCMurphy5 years ago
OK. I have never had the need to deal with NIOS before. Obviously I have a learning curve here. I don't even see Nios Command Shell in 21.2
