AMa
6 years agoBLVDS Question
According to datasheet, when USE_TERMINATION_CONTROL set to TURE. It will be able to use seriesterminationcontrol and seriesterminationcontrol_b to change the serial termination on Cyclone 10 LP de...
SreekumarR_G_Intel
6 years agoTo assign an OCT termination to an LVDS input pin,Can you use the setting as below
set_instance_assignment -name INPUT_TERMINATION DIFFERENTIAL "OCT 100 OHMS" -to <pin Name>
Thank you ,
Sree
