15 years agoBemicro SDK 80 I/O pins from edge connector
Hi, I would like to know how is the compiled .SOF file provided in the lab material uses the 80 pins edge connector. Because i can see that, Eclipse IDE recognizes 2 32bits GPIO being used in t...
15 years ago --- Quote Start --- I've tried that, non of them are configured to be output, all inputs... --- Quote End --- Your original question did not mention you cared about the direction. That would be a function of the SOPC system. --- Quote Start --- Which means i cant really use NIOS2 design... such a nicely designed FPGA, what a waste.:( --- Quote End --- Yep, I agree that it was a bad choice to select a memory that was not directly supported by Altera's IP. --- Quote Start --- Tried that too.. they will only allow you to use it for 1 hour everytime you compile. --- Quote End --- That is a pain. --- Quote Start --- I would much rather get a Terasic DE0-nano than Bemicro Nano, since they provide important IP cores. I found out, i could actually use the SDRAM controller that comes with SOPC builder, just a little timing configuration. --- Quote End --- The Terasic boards are all good. Cheers, Dave
