16 years agoBemicro NIOS lockup on EPCS access
Hello, I have installed the EPCS flash on my Bemicro and set the jumper accordingly. I can load an FPGA design into the EPCS using the Quartus Programmer and have it load successfully, so the ...
16 years agoamilcar,
Thank you. I switched to 9.1 SP2 and it works now. I had to place "jtag_hw_arrow_usb_blaster.dll" in "C:\altera\91sp2\quartus\bin" for the programmer to detect the cable. However, the normal USB-Blaster will NOT work with the DLL in place. I had to change the extension of the DLL to disable it before the USB-Blaster works. --Jeff
