17 years agoBeMicro FPGA-based MCU Evaluation Board
This is the new BeMicro FPGA-based MCU Evaluation Board thread. Please post your questions and comments within this thread. Documentation and purchasing information can be found at www.arrow.com/bemi...
14 years agoDoes jtagconfig work at all? (Probably not, since its likely a driver issue)
Here's what the factory default outputs:
$ jtagconfig -n
1) USB-Blaster
020F30DD EP3C25/EP4CE22
Node 0C006E01 JTAG UART# 1
Node 19104600 Nios II# 0
Node 0C006E00 JTAG UART# 0
Do you see the USB-Blaster under the device manager? What version of the drivers are installed? I can have a look at my Win7 machine tomorrow and see what it says. The other issue with Win7 is that it does not allow VirtualBox to capture the USB-Blaster to a virtual machine, so you can't just try installing WinXP or Linux, since you then cannot access the USB-Blaster. If you know how to dual-boot your development machine, you could install Centos 6.2 or Ubuntu 11.10. Both work fine with the USB-Blaster. Cheers, Dave
