14 years agoBemicro Cyclone III(not SDK) and EPCS16 problems...
Hello, I'm using the 'original' Bemicro kit (not the SDK kit) for a simple project implemented with a state machine in VHDL, so no Nios and no SOPC builder I've never used those. I've been u...
14 years agoThere are two simple ways to load the SFL IP to your FPGA to access the serial flash through indirect JTAG programming.
- load the default factory image shipped with Quartus sfl_ep3c16.sof - instantiate the SFL IP in your design after generating the code in MegaWizardsfl_inst : sfl PORT MAP (
noe_in => '0'
); You additionally need to convert the configuration stream to *.jic with the Quartus conversion tool.
