16 years agoBeMicro and Programming Under Linux
Hello, I have just received a BeMicro and have completed the tutorial up to the point where I need to download the SOF file. Unfortunately, I cannot get Quartus II v 9.1sp2 Programmer to r...
15 years agoIt is not just Linux having the problems you are seeing. I have the same issue with XP Pro 64bit, but I can't find any help. The Arrow rep just told me to switch to a 32bit machine, but good luck finding new 32 bit hardware nowadays, it is all 64 bit. I had to switch to XP Pro due to the stock OS being Win7.
I am using xp pro 64 bit , good luck getting 32 bit hardware now. So far all my development applications have installed with the exception that I can not get the USB Blaster driver to install properly which seems to be required to support the BeMicro eval board. - When I run the setup file under the BeMicro\programmer folder, the install process seems to work to install the jtag_hw_arrow_usb_blaster.dll When I check out drivers under Device Manager I see 2 drivers installed: - Arrow USB-Blaster Port A - Arrow USB-Blaster Port B - However, when I work through the BeMicro tutorial and get to the 5.3 section part where it wants me to click Hardware Setup and select Arrow-USB-Blaster in Quartus (I am using quartus v10 sp1), the only option I see is "No Hardware" I have to get results rolling fast, can someone help me get past the XP Pro 64 bit USB Blaster driver Quartus v10 recognition issue. Thank you very much, Dale
