aamodini
2 years agoAvalon-MM master burst transfer
I am transferring data from Nios (master) to the FPGA fabric (slave) through the Avalon-MM interface. How do I set the burstcount parameter on Nios and initiate a burst transfer? I don't see a...
ShengN_altera
2 years agoHi,
Check this document link https://faculty-web.msoe.edu/johnsontimoj/Common/FILES/n2cpu-nii5v1gen2.pdf (page 107, 108). Just need to enable the Add burstcount signal to instruction_master. Not need to set the burstcount parameter on Nios, burst adapters will be inserted for the burst compatibility between Nios (master) to the FPGA fabric (slave).
Sheng
