dpk23
2 years agoArria10 FPGA's Emif Hard IP showing deviation in behavior from expected Avalon bridge protocol
Hi, we are using the Intel device kit DK-DEV-10AX115S-A with 10AX115S2F45I1SG FPGA device and HiLo DDR4 mounted on this. The FPGA design has a cortex core with AXI bridge integrated with Emif hard ...
- 2 years ago
Hi, this works : inverting the amm_ready from EMIF
thanks for the help!
sstrell
2 years agoYou're saying amm_ready is waitrequest? That doesn't make sense since "ready" is not a standard Avalon signal. And if "ready" is the signal you are using, it sounds like an inverted version of waitrequest which would make the behavior you show in your Signal Tap capture expected.
Can you verify this is actually waitrequest? I've never seen it referred to as "ready".
