Arria10 FPGA's Emif Hard IP showing deviation in behavior from expected Avalon bridge protocol
- 2 years ago
Hi, this works : inverting the amm_ready from EMIF
thanks for the help!
This doesn't make sense (and you're not showing the waitrequest signal in question). If waitrequest is asserted, control signals must continue to be asserted until 1 clock cycle after waitrequest is deasserted. If you are holding the read signal past this point, then yes, multiple reads will occur.
I'm assuming these are the signals at the EMIF. You should also look at the signals on the other side, whatever is issuing the commands.
- dpk232 years ago
Hi, the waitrequest is same as amm_ready
I have attached snapshot of avalon read/write protocol as per spec - for a single data transfer
The read (along with other control signals) is delayed as long as the waitrequest is asserted
The commands issues from master side follow the protocol, i.e. as long as amm_read/waitrequest is asserted the control signals dont change.
But the EMIF is sending multiple readdatavalids - instead of just 1 - and also even before the amm_read/waitrequest is de-asserted
