11 years ago[ARRIA V GX STARTER KIT] USB read/write registers to Arria V
we have an Arria V GX starter kit on which the Arria V FPGA firmware is programmed through a MAXII FPGA in which is implemented a USB blaster II. with the appropriate firmware on the Arria V, the Board Test System software is able to access several parts of the hardware of the board, connected to the Arria V : user push buttons, user leds, .... thus, if I'm correct, it would be possible to read and write registers (with a PC connected to the kit via USB) in the Arria V. is it really possible ? do you have a link to any documentation for doing that ? and especially on this dev. kit ? thank you for the help. best regards ronic
