Arria 10 SoC Development Kit: Serial Lite II Example Design and Documentation
I understand that you want to evaluate SerialLite II IP and need example design for it. As you know, it requires a special license to be generated for which we have to contact our marketing team. They will need your company and contact details to evaluate and your machines NIC ID for license generation. All this might take good amount of time.
However, I just wanted to check if you have evaluated our Serial Lite III Streaming or Packet IP or Interlaken IP. Possible to use them?
1. Serial Lite III Streaming Intel® FPGA IP Quick Reference
A bunch of IP are supported for 20nm (Arria 10) devices which you may find from the following link:
Ashlesha
I wish that was an option. However, we need to interface into an existing device that outputs Serial Lite II. From my research, it appears that Serial Lite II is not compatible with Serial Lite III - which is why we need Serial Lite II.
- JHenk31 year ago
Hello - can we move this forward? I do not want to publish the info requested publicly, is there a private channel to pass the company name, NIC info, etc? Thank you.
