Arria 10 SoC Development Kit: Not able to run Intel FPGA AI Suite Soc Design Example
- 2 years ago
Hi Rajan,
Our factory apps team gotten back to me on this case and mentioned that the latest Arria 10 SoC rev E. boards have a slower SDRAM (BOM change) and they have already change the design example in 2024.1 AI FPGA Suite to be able to accommodate these boards as well as the previous versions of the FPGA AI Suite do not work on A10 SoC rev. E boards.
Could you try on the design example in 2024.1 AI FPGA Suite?
Kian
Hi Rajan,
We have not heard back from you for some time.
I will proceed set this case to close-pending since a solution had been provided. I've also did some basic sanity check on my end and confirm the 2024.1 example resolves the issues that we identified previously.
Thanks for using Intel forum and sorry for the delay in getting back to you on the issue. Do let us know or create a new thread if there is still issues encountered at your end and we will support you from there.
Kian
