Arria 10 SoC Development Kit: Not able to run Intel FPGA AI Suite Soc Design Example
- 2 years ago
Hi Rajan,
Our factory apps team gotten back to me on this case and mentioned that the latest Arria 10 SoC rev E. boards have a slower SDRAM (BOM change) and they have already change the design example in 2024.1 AI FPGA Suite to be able to accommodate these boards as well as the previous versions of the FPGA AI Suite do not work on A10 SoC rev. E boards.
Could you try on the design example in 2024.1 AI FPGA Suite?
Kian
Hi Rajan
Thank you for reaching out our FPGA community. I'm Kian and I will be looking into this case.
Let me investigate on my end first to see any known issues with the pre built image and I will get back to you .
Kian
- KianHinT_altera2 years ago
Hi Rajan
I apologize for the delay in getting back, so far I've checked through our cases , knowledge base or any known issues, and looks like there's none . Initially I suspected the DIP switches and jumper settings as it has slight config differences from the rocketboard (https://www.rocketboards.org/foswiki/Documentation/Arria10SoCGSRD) but you mentioned that running the image from rocketboards on SDCARD has no issues , so probably that rule out the switches and jumper settings.
Currently I'm setting up a system to do the test on the precompiled image with Arria 10 to see whether I could duplicate the same issue out on my end and will update you later
Kian
