jrrguzman
7 years agoArria 10 Soc Dev Kit and LMK04828
Hi, is it possible to access the LMK04828 at the Arria 10 SoC dev board using the HPS SPIM1 interface? The tools from TI does not seem to recognize the USB. Kind regards
EBERLAZARE_I_Intel
7 years agoHi,
I apologize for the misunderstanding.
1) I sent a zip file that should contain all the information regarding the usage of the clock cleaner to you via message. Can you check your inbox if you have received it?
2) I cannot confirm if the clock cleaner is accessible from the HPS, I did not found any information regarding this in our documentation and the file given.
Regards.
vage
6 years agoHello,
I also need this information regarding the usage of the clock cleaner on the very same board. May I also have it please?
Many thanks and best regards.
