User1580871742356367
6 years agoArria 10 HPS DDR4 calibration fail and no emif_usr_clk
Story: HPS DDR4 calibration failed (discrete, 32bit). No emif_usr_clk by putting signal tap PLL locked both local_cal_success and local_cal_fail are LOW Questions: Why there was no emif_us...
6 years agoThe fitter was failed if using HPS EMIF DDR4 pins (same as A10 SOC Eval Kit) when generating FPGA EMIF example design.
Alert_n pin is on AG24 and the pins are working for HPS EMIF ( GHRD NAND design)
Have played with Alert_n settings etc. in Parameters (DQS group, Addr/CMD or auto) and no luck.
Any suggestions?
ybin
6 years agoYou need to check whether all the pin location assignment and IP parameter is the same as GHRD .
