Arria 10 Gx board, SFP connection no link
Could you try to do internal loopback on the device to check whether the device can function normally?
Zi Ying
Hello, I have had success in getting the LL10G_10G_USXGMII example project (posted earlier) to connect.
I had to turn off USXGMII Mode and revert to 10GBase-R mode. I am not sure why this affected the link but it allowed me to proceed.
I am now able to send and receive data at 1G speeds.
I have one remaining issue. The internal PHY port 'operating_speed' always shows as "000" which I believe corresponds to at 10G connection. This is true even when I am connected to 1G or 2.5 G only devices. So it is not updating to the correct current speed.
How can I get reliable information from the PHY internally about its current connection speed? I do not see a register that I can read which will tell me this information. How can I limit the allowed connection speeds? For example, If I cannot run at 10G speeds I do not want the PHY to be able to connect to 10G only devices.
