TSchu3
2 years agoArria 10 Gx board, SFP connection no link
Hello all, I am attempting to bring up a link on a new Arria 10 Gx board, using the SFP+ connector. I started by generating an example design for the Low Latency Mac, with the 1G/2.5G Ethernet Examp...
ZiYing_Intel
2 years agoHi,
Can you share your .qar file here?
zying
- TSchu32 years ago
Hello, I have attached two example projects that I believe should bring up a link on the Arria 10 GX board, neither do.
qts_com_23_2_0_94 is from the example projects that come with the dev board files.
LL10G_10G_USXGMII is generated from the platform designer for the Low Latency 10G mac. I have manually assigned pins to it for the Arria 10 board. It also fails to bring up a link.
I am using the SFP+ connector.
Thanks again for any advice.
