16 years agoAre the possibilities to use pins as custom I/O's for external wiring - NEEK
Hi, I've got a NEEK-Starter-Board (Cyclone III, Multimedia Board, Terasic LCD Daughter Card) to work with. The overall goal is to wait for button touches on the touchscreen, then send appropri...
16 years agoThanks.
In the meantime, I tried to find as many pins as possible. Here are my results: - SDA, SCL possible - UART_TXD possible, with an advantage: you can see the traffic via the TXD-status LED - UART_RXD not possible, it's just one-way, so not usable as an output - SD-Card possibe - VGA_VS, VGA_HS couldn't get these working, no idea why ... Unfortunately, there are pull-up resistors and resistors in series within the PS2 and SD-Card lines which might bring disturbances. Could cause problems with some busses. not tested yet: - PS2 clk and data pins I don't know yet which pins to use as all of them have further electronical components connected. Maybe I have to find a way to use the first unused third (~30 pins) of the HSMC. Are there any HSMC adapters which split up the three parts? Regards, Leo
