15 years agoAPEX fpga
Hi, I bought a Nios Excalibur board (second user). I thought I could use quartus II 10.0 web edition to run it but Apex FPGA is not an option when you open a new project. Is there any way I can play ...
15 years agoRe installed the stand alone programmer. It now works and so does 10.0 again. 7.2 still has the same problem but , if I load it then rerun the stand alone programmer and ask it to recognise usb blaster, close it then use the embedded 7.2 programmer it works after a few interogations?? I have sucessfully programmed the board using this method and once it works it continues to work until I shut down the program so no big deal.
Thanks again Graeme.
