Altera USB Blaster on Windows 10 code 39 error
- kozakoff7 years ago
Hi Vikas,
Thank you for this additional troubleshooting information. Neither of these links fix the problem I am experiencing. That said, I was able to connect the DE0-Nano Cyclone IV on another computer (Mac Mini ~2013) with the same Windows version and build. The instructions you provided work flawlessly on the Mac Mini. The computer that does not work is a Microsoft Surface Book 2. I recently noted that an older USB 2.0 hub I have also does not work on the Surface Book. I think the problem I am experiencing is due to some USB compatibility problem with the Surface Book 2. Regardless, I have a working solution for the DE0-Nano so I am good to go.
Thanks again for you assistance.
-Steve
- GSmit516 years ago
I'm having the same issue on the same windows build except I'm using a Dell OptiPlex desktop PC. On another Dell PC with Windows 10 the usb-blaster installed correctly. I also get the same issue on a Dell laptop.
- gaetanp5 years ago
I am having the same issue with a Surface book
Windows 10 Home
Version: 1909
OS build: 18363.1139Did anyone solve this problem?
Do I need to get a new computer?
