Altera USB Blaster III LEDs usage
- 2 years ago
Hi AnttiLukats,
Thank you for your patience, and I sincerely apologize for not addressing your question directly in my earlier reply.
Regarding your inquiry about the meaning of the RGB LED colors on the on-board USB Blaster III, please find the detailed information below:
- Off: No power / not connected / suspend mode
- Blue: Connected, not in use
- Green: Connected, an application is using JTAG, no traffic
- Green flickering: Connected, data is moving through the JTAG interface
- Purple flashing: Identify function has been triggered on this cable
If you have further questions or need additional clarification, please don’t hesitate to reach out. I'm here to help and will ensure your concerns are addressed promptly.
Thank you again for bringing this up, and I appreciate your understanding.
Fakhrul
as stated, I tried with Arrow-USB-Blaster, Port A is set to 245FIFO and D2XXX mode in EEPROM. Default FT4232H setting is UART and VCP.
You are talking about official USB-Blaster III and onboard solutions. Where did you get the info?
I'm possible talking too much
can you post your String desciption screen from FT_PROG. Here I really have no luck enabling UB3
