ZVere
6 years agoALTERA Scatter-Gather DMA core
I'm looking for a windows driver for the DMA feature.
Can you please help ?
Thank you,
Zvika
- MEIYAN_L_Intel
May I know which driver you are looking for?
Do you make connection to on chip ram/rom through dma in Platform Designer?
If not, could you tell more detail about the driver?
- ZVere
Hello, Thank you for your reply. Do you have any experience with the DMA core described here ? https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pcie_avmm_dma.pdf I have to develop a windows driver for it. Do you know if ALTERA provides reference source code ? According to the PDF, maximum number of descriptors is 128. Can you confirm ? What should we do in case we need more ? Best regards, Zvika
- Nathan_R_Intel
Contributor
Hie Zvlka,
Please check my replies to your questions below:
- Do you know if ALTERA provides reference source code ? - No the reference source code is encrypted. Its only available for usage with Intel FPGA.
- 2. According to the PDF, maximum number of descriptors is 128. Can you confirm ? Yes it is.
- What should we do in case we need more ? You will need to use external descriptor using external memory. The information is available in the following user guide:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an708.pdf
Nathan
- ZVere
Hi Nathan, Thank you very much ! Best regards, Zvika
- Nathan_R_Intel
Contributor
Sure Zvika,
Glad I could be of help.
Nathan
