dsun01
Contributor
3 years agoaltera_pcie_gui of Release_1113_80000000 not run
Dear Intel Support and Expert,
I am learning PCIe through AN708, I loaded to the A10GX dev board, and can see the Altera PCI device on PC1 after I installed the driver. I followed the instruction...
- 3 years ago
Hi David,
An alternative suggestion to you is to try on Linux version of the tool works on Ubuntu.
However it does not have all the features that are available in Window, for example error checking is missing
Wincent_Intel
Wincent_Altera
3 years agoHi David,
I check with the related team since the beginning of the window support for Gen3x8_AVMM_DMA_-_Arria_10 design example window compatibility.
I just got feedback from them now.
I'm sorry to inform you that the design that you linked to is currently only supported for 64 bit Windows 7.
The design was tested for that OS. We cannot guarantee the results on Windows 8+.
Hope this answer your question, I do apologize if any inconvenience cause.
Wincent_Intel
