altera_pcie_gui of Release_1113_80000000 not run
- 3 years ago
Hi David,
An alternative suggestion to you is to try on Linux version of the tool works on Ubuntu.
However it does not have all the features that are available in Window, for example error checking is missing
Wincent_Intel
Hi David,
I understand your frustration, to be honest I feel the same as well.
But anyhow you can file your question in forum, I might not able to answer accurately sometime, but I will try my best to help.
"I can see the Altera PCI device after I load FPGA and reboot windows. which means everything is working( FPGA loaded and driver can see the device) before I run the altera_pcie_gui. "
If I understand correctly, you are able to run the design in Window 10 right ?
Is there any other problem that I can assist you ?
Wei Chuan
