IDeGu
6 years agoAltera DE-10-Nano UART Rx and Tx in Pin Planner
Hi there, I'm doing a NIOSII tutorial but I got stuck to the UART pins assignment in the Quartus Pin Planner. Specifically I have to connect the Rx and Tx to their respective pins. Since I ha...
IDeGu
6 years agoGood point dlim!
I have discovered a program utility called System Builder that was shipped with the unit. Basically it generates a Quartus project with the pin declarations that you need and bypass the troubles I had with Pin Planner.
It ended up working correctly and I took some time looking into the generated files.
The below is part of the Verilog file which is generated by the System Builder:you can see the HPS pins being assigned in what is intended to be the top file.
// This code is generated by Terasic System Builder
module DE10_NANO(
//////////// CLOCK //////////
input FPGA_CLK1_50,
input FPGA_CLK2_50,
input FPGA_CLK3_50,
//////////// HPS //////////
inout HPS_CONV_USB_N,
input HPS_UART_RX,
output HPS_UART_TX,
//////////// KEY //////////
input [1:0] KEY,
//////////// LED //////////
output [7:0] LED,
//////////// SW //////////
input [3:0] SW,
//////////// GPIO_1, GPIO connect to GPIO Default //////////
inout [35:0] GPIO
endmodule
While in the QSF file you can see the pins being assigned.
# Build by Terasic System Builder
# CLOCK
set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to FPGA_CLK1_50
set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to FPGA_CLK2_50
set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to FPGA_CLK3_50
set_location_assignment PIN_V11 -to FPGA_CLK1_50
set_location_assignment PIN_Y13 -to FPGA_CLK2_50
set_location_assignment PIN_E11 -to FPGA_CLK3_50
# HPS
set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to HPS_UART_RX
set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to HPS_UART_TX
# End of pin assignments by Terasic System Builder
#============================================================Still I'm unsure how I was supposed to know that, but maybe I missed it somewhere in the number of tutorial I checked on the topic.
Thank you again dlim, I appreciated a lot your input!
Iggy
