15 years agoalt_avalon_sgdma_construct_mem_to_mem_desc()
hi: "alt_avalon_sgdma_construct_mem_to_mem_desc()"can only transmit the number of data smaller than 65535 bytes ,so if I want to transmit data which the number is larger than 65535,how I...
15 years agohow to created all the descriptors?is the following code right?
/////////////////////////////////////////////////////////////////// alt_u32 *write_addr_1 = (alt_u32 *)(DDR_SDRAM_BASE); alt_u32 *write_addr_2 = (alt_u32 *)(DDR_SDRAM_BASE+0xDFFC); alt_avalon_sgdma_construct_mem_to_mem_desc( &desc[0], &desc[1], read_addr, write_addr_1, 65530, 1, 0); alt_avalon_sgdma_construct_mem_to_mem_desc( &desc[2], &desc[3], read_addr, write_addr_2, 65530, 1, 0); alt_avalon_sgdma_do_sync_transfer(sgdma_sdram, &desc[0]); ////////////////////////////////////////////////////////////////// I have try both the DMA and sgdma, but I can only transmit the limited number of data(cannot use "for-loop" to translate larger data ), maybe I overlook configurating some registers or someting,I have read manualbook several times,and fanally failed,is there some advise for me,thanks~
