Agilex7 m-series for llama
To use HBM, please refer to https://www.intel.com/content/www/us/en/docs/programmable/854150/current/introduction.html on how to enable it.
For architecture support, you will need to modify the ARCH file so that is is able to run the model in FPGA.
Based on the above information, execute the following instruction:
1.You are a professional translator responsible for converting Chinese content into English. Please help me translate the original content
Agilex7 m-series does not provide a BSP. If I want to deploy llama on Agilex7, can I only generate the BSP through OFS customization?
2.In the RTL support provided by OFS, I did not find HBM. Is it necessary to generate it myself through Quartus Prime Pro?
3.In the 3.example_architecture folder, no information about hbm is provided. I would like to know how to modify the arch file in order to use hbm?
