Agilex7 m-series for llama
To use HBM, please refer to https://www.intel.com/content/www/us/en/docs/programmable/854150/current/introduction.html on how to enable it.
For architecture support, you will need to modify the ARCH file so that is is able to run the model in FPGA.
- lexie111 year ago
Based on the above information, execute the following instruction:
1.You are a professional translator responsible for converting Chinese content into English. Please help me translate the original content
Agilex7 m-series does not provide a BSP. If I want to deploy llama on Agilex7, can I only generate the BSP through OFS customization?
2.In the RTL support provided by OFS, I did not find HBM. Is it necessary to generate it myself through Quartus Prime Pro?
3.In the 3.example_architecture folder, no information about hbm is provided. I would like to know how to modify the arch file in order to use hbm? - lexie111 year ago
1.Agilex7 m-series does not provide a BSP. If I want to deploy llama on Agilex7, can I only generate the BSP through OFS customization?
