spectralsensors
2 years agoAgilex 7: Not able to access the FPGA fabric from HPS through light weight AXI bus
Hi, Objective: We are trying to access the FPGA fabric from the HPS region through the light weight AXI BUS. Issue: I am not able to access the address map 0xF900_0000. I am using the SOF from roc...
tehjingy_Altera
2 years agoHi Sanjat
Did you enabled the lightweight bridge in the Quartus Project?
Could you please try running out the GHRD RBF to check the bridge connection is working first?
https://www.rocketboards.org/foswiki/Documentation/AgilexSoCGSRD
Jingyang, Teh
