Agilex 7 FPGA Short-Circuited Without Physical Damage – Need Guidance
- 1 year ago
Please hold on we processing your FA.
regards,
Farabi
For your questions 2 and 3, I think the suggestion we can give should be based on the exact failure symptom. Could you please confirm the following information?
1- Did you measure certain Test Point on the board to confirm the "short"? What are the FPGA pins related to the "short" point?
2- What is the exact failure you observed? Did you observe a specific functional failure? Are there some abnormal output signals? Or basically there's no function working?
3- Did you check the configuration status of FPGA? If you try to detect and program the FPGA with Quartus Programmer, is there any error message in Programmer?
For your question 1.
Actually, according to functional failure cases reported by other customers, it is quite rare for us to see physical damage. Even for some units with a lot of pins short to ground, there's actually no visible damage.
Some examples below may cause visible damage, but it still depends on the severity:
-- Mechanical/Thermal induced: The unit was subjected to physical damage. The unit was subjected to high temperature reflow/rework process before baking to clear the humidity. (I think for such cases, customer generally do not find us. )
-- Electrical Induced: The unit was subjected to excessively long term of high current.
Xiaoyan
- VBalamurugan291 year ago
Hi Xiaoyan,
For your questions 1 and 2:
After power sequencing and all Agilex power rails were confirmed to be stable then we started programming FPGA.
I have started testing with DDR4.
Initial testing up to 3 Gigabits showed no errors. When extending the address range for full DDR4 capacity, a sudden spike in load current was detected on the RPS. The board was immediately powered down to prevent damage.
A detailed inspection of all power rails was conducted. The following Agilex 7 FPGA power rails were found shorted:
Power Rail
Voltage Level
VCCRCORE
1.2 V
VCCL_SDM
0.8 V
VCCPLL_HPS
1.8 V
VCCPLL_SDM
1.8 V
VCC_ADC
1.8 V
VCCPT
1.8 V
Both FPGA and voltage regulator sides were isolated and tested independently. Short circuits were found only on the FPGA side. regulators were confirmed to be functioning correctly.
