malcolm_locke
1 year agoAgilex 5 Installation in linux
Hi, I am trying to install quartus 25.1.1 with agilex 5 device support under linux (wsl2). I use the following command sudo ./qinst.sh --cli --components quartus,agilex5 --download-dir /tmp --insta...
RichardT_altera
1 year agoMay I know which Linux OS you’re using? Also, you mentioned WSL2—do you mean you installed WSL2 in Linux?
If so, could you share why you have it installed if your primary OS is Linux?
As WSL (Windows Subsystem for Linux) is installed on Windows OS only, not on Linux OS.
Unfortunately, there’s no command available to list all the installed devices.
As an alternative, you can open the installer in GUI mode to check which devices are installed.
Richard Tan
malcolm_locke
1 year agoHi Richard. Sorry for the confusion. I am using WSL2 under Windows 10.
I don’t think I can do anything in gui mode? so am trying to confirm if agilex 5 support is installed in cli mode.
