15 years agoAdvanced Boot Copier -
Hi, Advnaced Boot Copier for CFI Flash memory loads and jumps to a simple application (Hello World code). But it fails to run a "larger" application. The boot copier successfully validates the...
15 years ago --- Quote Start --- Hi OnePlusOne - having similar issues here - did you get anywhere in your debug? C --- Quote End --- I passed that. But I could not recall what exactly was the fix. It has been for a while and I am not using that boot loader for now. I believe there is something to do with the interrupts.
