12 years agoAccessing EEPROM on I2C Bus 0 - Altera Arrow SoC kit
Hi experts,
On detecting the I2C devices on I2C Bus 0 for Altera SoCkit by using i2cdetect command in linaro filesystem, $ i2cdetect -y 0 Error: Can't use SMBus Quick Write command on this bus But i was then able to detect EEPROM and LCD on I2C Bus 0 using the command as follows, $ i2cdetect -r 0 WARNING! This program can confuse your I2C bus, cause data loss and worse! I will probe file /dev/i2c-0 using read byte commands. I will probe address range 0x03-0x77. Continue? [Y/n] y 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- UU -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- But when i try to read/write to EEPROM on I2C0 using I2C SMBUS read in code / using i2cget, im getting error: read failed. So on trying to access using /sys/bus/i2c/devices/0-0051, i face a time out issue as follows, cat: /sys/bus/i2c/devices/0-0051/eeprom: Connection timed out And its I2C debug messages are, i2c i2c-0: master_xfer[0] W, addr=0x51, len=2 i2c i2c-0: master_xfer[1] R, addr=0x51, len=128 i2c_designware ffc04000.i2c: i2c_dw_xfer: msgs: 2 i2c_designware ffc04000.i2c: i2c_dw_isr: Synopsys DesignWare I2C adapter enabled= 0x1 stat=0x10 i2c_designware ffc04000.i2c: i2c_dw_isr: Synopsys DesignWare I2C adapter enabled= 0x1 stat=0x110 i2c_designware ffc04000.i2c: i2c_dw_isr: Synopsys DesignWare I2C adapter enabled= 0x1 stat=0x150 i2c_designware ffc04000.i2c: i2c_dw_handle_tx_abort: slave address not acknowledged (7bit mode) Any idea/help on accessing the EEPROM on I2C0 will be much more appreciated. Thanks, Dhiv1 Reply
there is no EEPROM on the Arrow SocKit kit. There is, however, an EEPROM at address 0x51 on the Cyclone V SOC Development Board. Because all the standard Device Tree Blobs seem to directly support the Cyclone V SOC board, the I2C slaves in your device tree are probably the ones for that board and not the SocKit. if you run the command:
(renaming socfpga_cyclone5.dtb to whatever dtb you are using...) you will probably see this:dtc -I dtb socfpga_cyclone5.dtb -O dts
That is for the Cyclone V board and not for the SocKit. You would need to get rid of those and add entries for the components that are on the SocKit. The SocKit has the G-Sensor (ADXL345 at address 0xA6) and a connection on the LTC 2x7 for connecting whatever you want. --- Quote Start --- Hi experts, On detecting the I2C devices on I2C Bus 0 for Altera SoCkit by using i2cdetect command in linaro filesystem, $ i2cdetect -y 0 Error: Can't use SMBus Quick Write command on this bus But i was then able to detect EEPROM and LCD on I2C Bus 0 using the command as follows, $ i2cdetect -r 0 WARNING! This program can confuse your I2C bus, cause data loss and worse! I will probe file /dev/i2c-0 using read byte commands. I will probe address range 0x03-0x77. Continue? [Y/n] y 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- UU -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- But when i try to read/write to EEPROM on I2C0 using I2C SMBUS read in code / using i2cget, im getting error: read failed. So on trying to access using /sys/bus/i2c/devices/0-0051, i face a time out issue as follows, cat: /sys/bus/i2c/devices/0-0051/eeprom: Connection timed out And its I2C debug messages are, i2c i2c-0: master_xfer[0] W, addr=0x51, len=2 i2c i2c-0: master_xfer[1] R, addr=0x51, len=128 i2c_designware ffc04000.i2c: i2c_dw_xfer: msgs: 2 i2c_designware ffc04000.i2c: i2c_dw_isr: Synopsys DesignWare I2C adapter enabled= 0x1 stat=0x10 i2c_designware ffc04000.i2c: i2c_dw_isr: Synopsys DesignWare I2C adapter enabled= 0x1 stat=0x110 i2c_designware ffc04000.i2c: i2c_dw_isr: Synopsys DesignWare I2C adapter enabled= 0x1 stat=0x150 i2c_designware ffc04000.i2c: i2c_dw_handle_tx_abort: slave address not acknowledged (7bit mode) Any idea/help on accessing the EEPROM on I2C0 will be much more appreciated. Thanks, Dhiv --- Quote End ---i2c@ffc04000 { # address-cells = <0x1>; # size-cells = <0x0>; compatible = "snps,designware-i2c"; reg = <0xffc04000 0x1000>; interrupts = <0x0 0x9e 0x4>; clocks = <0xb>; status = "okay"; speed-mode = <0x0>; eeprom@51 { compatible = "atmel,24c32"; reg = <0x51>; pagesize = <0x20>; }; rtc@68 { compatible = "dallas,ds1339"; reg = <0x68>; }; };
