16 years agoAccessing Data on the FPGA or SDRAM from a PC
I am using a DSP Dev. Kit, Cyclone III Edition: In order to verify my system and to test the idea behind the prototype I would like to access data stored on the FPGA as well as on the DDR2 SDR...
16 years agoThank you!
Did I see that correctly that Signaltap's data length is limited to 128k Samples? Therefore, if I want to transfer more data, I need to build a USB-interface? Thanks in advance for further advice!
