17 years agoabout Spansion flash
Hi, I use Spansion flash S29GL256N on Stratix II GX audio-video development board. I checked the datasheet and it should be OK to use the AMD29LV128M flash driver that is provied as Presets by...
17 years agoHi,
i still could not get the spansion flash s29GL256N11TFI020 work on the stratix II GX audio video board. This flash is not in the list of tested flash memories and it did not work when using the AMD29LV128M series of flash as Presets. I also tried to use "custom" Presets,address width 24 bits, data width 16 bits, timing: setup 45 ns, wait 160 ns, hold 45 ns. But it did not work either. I wonder if somebody succeeded in getting it work on this board ... Thank you in advance!
