17 years agoabout Spansion flash
Hi, I use Spansion flash S29GL256N on Stratix II GX audio-video development board. I checked the datasheet and it should be OK to use the AMD29LV128M flash driver that is provied as Presets by...
17 years agoIf you open TimeQuest and run the "Top Failing Paths" report, it will show you the full hierarchical names of the failing path. You know it's a hold timing violation because TimeQuest tells you that.
Jake
