17 years agoabout Spansion flash
Hi, I use Spansion flash S29GL256N on Stratix II GX audio-video development board. I checked the datasheet and it should be OK to use the AMD29LV128M flash driver that is provied as Presets by...
17 years agoAll of the above mentioned assignments are design specific. They are derived from the PHY IC's timing specifications as well as the PCB board trace delays.
With regards to the timing error. There appears to be one data path failing. I'm going to upload a new version of the MAC shortly. The eCos guys have started using the MAC and have uncovered a few issues which I have repaired. In addition to those changes I will modify the code slightly to ease the timing on this failing path. Jake
